Impeller question
srowland76
When replacing the impeller does it matter which way it goes back in the housing? I made sure all the "arms" were going the same way but didnt know if they had to be turning a particular way.
robert graham
Re: Impeller question
The impeller has dots on one side and slash marks on the other, one is up and the other is down. The drive shaft turns clockwise, so the impeller blades need to be turned accordingly. Maybe pull it apart and be sure you've got everything right. Check: SIMYamaha-Andy's Tips, for step by step instructions with photos on impeller replacement and several other repair/maintenance procedures, Good Luck!
srowland76
Thank you so much for the reply, i pulled it apart and made sure everything was right so im going to drop it in the water very soon and check her out.
