The parts breakdown (BRP site)shows no gaskets above or below impeller plate (or anywhere under housing for that matter). Is this correct? The only impeller I've replaced was a Merc, which had gaskets above and below plate, IIRC.<br />If no gaskets, then I would only need:<br /><br />Impeller<br />Driveshaft seals (below impeller)<br /><br />Am I right?<br /><br />Thanks,<br /><br />TC
