Re: Impeller Replacement Costs
Four years old? I would reccommend a complete pump replacement not just an impeller. Complete pump will cost you $100.30 from the shop. If the shop pulls the complete drive, then you have the cost of the gasket remount kit which will run another $5-6 bucks. Add a refill of gear oil, hopefully you didn't wait 4 years to change that. That's another $15-20. I would plan on 2 or less hours for labor but then I deal with salt water units and have seen the jobs last for most of the day. I would put the cost closer to $250. Now I'm sure someone will raise the claim that you can buy your parts cheaper yourself and that is true, but don't expect the shop to install them. That's kinda like taking your own steak to the restaurant and asking them to cook it. I worked on a fresh water unit once years ago, couldn't believe how easy it was. You guys up north have it made.
