1992 FourWinns Horizon 200 20 ft - Impeller replacement. Engine: 5.8 L V8, 1991 OMC Stern Drive.
I replaced the impeller a few months ago but when I started it up recently the impeller did not pump water and then melted from the heat of spinning dry. Cracked the housing as well. I had the hose connected but there was no flow through the motor. I shut the motor off pretty quickly, maybe 1 minute but I was too late !!. Melted the impeller. Am I right in assuming that it melted from spinning dry? Why didn't I get water flow to it to "Prime" the impeller? What can I check?
When the hose is connected should water enter the impeller through that small hose?
