Hello,
I just purchased a 1964 18HP johnson that is in need of repairs and a tune up. Previously I posted a topic on the replacement of the impeller on a 1964 5.5HP Johnson and was told that the powerhead would have to be removed. I am wondering if the same circumstances apply to replacing the impeller on this 18HP? Also plug/points info would be helpful! Gas/oil ratio is marked with a sticker by the fuel hookup as 50:1. Is this correct for the 18HP and also the 5.5HP? I have a 1963 5.5HP Evinrude that is 24:1 ratio. Thank you for your help!---Ownsbud56---P.S.--- When did they change the site?
