impeller rotation direction
jvstream
I'm installing an impeller in my 94 50hp mariner. Should I twist it into the impeller housing clockwise or counterclockwise. Forgot which way it came out....
saumon
Re: impeller rotation direction
Turn the driveshaft clockwise when viewed from top.
Put a dab of dishwashing soap onto the impeller then press the housing onto it while turning the driveshaft.
SparkieBoat
that is correct..I use grease..i am sure soap works great
