Impeller, Thermostat, ???
Moku'ula
As mentioned in a few other posts, I recently bought a 99 Four Winns with the VP 4.3 GLPWTR and SX outdrive. The boat looked to be perfectly maintained, BUT the impeller appears to have NEVER been replaced as all but four of the vanes were intact when I replaced it. I took the thermostat housing apart and found one vane and three other pieces of the impeller slowing the flow from the thermostat. I've got a replacement thermostat, gasket and o-ring on order and they'll be here end of the week.
Now for the money shot... Once I put the thermostat in and put everything back together, what should I be looking for as telltale signs that other pieces of the impeller that worked their way further downstream are causing issues?
Before tearing down the thermostat housing, when I put the muffs on and started the engine on the hose, exhaust water was running out the bottom of the transom rather than out of the prop. Is this a big concern? I'm thinking this is likely from the exhaust bellows which is probably overdue to be replaced.
Anyway, any feedback would certainly be appreciated.
Thanks.
Jef
jerryjerry05
Re: Impeller, Thermostat, ???
Don't worry about the exhaust bellows unless it comes loose or gets real loud.
The water at the transom is normal. If you got the vanes out then you should be ok.Jerry
chiefalen
You have power steering? If yes, the heat exchanger would be my bet. Only
other place to look. Wouldn't hurt to see if any pieces in there.
Moku'ula
Thanks for the feedback fellas.
Heat exchanger - OK - that'll be next on the list once I get the thermostat put back together this week...
Man - it sure would be nice to have a marine parts store locally...
I guess I should be happy the web exists...
Jef
hard-3
take the hoses off of the cooler and back flush it with a garden hose. It might be plugged with little rubber shavings . i found mine clogged with silicone sealer that someone had used on the raw water pump. most of the oil cooler tubes are less than 1/4 inch id and does not take much to plug
Jeff
tysonnathan
Jef
Yes, we all owe Al Gore a debt of gratitude.....
