Re: Impeller upgrade kit, Bravo3
Its not the one in the groove in the housing. That one is installed and just to kind of get our berings, I'd say that one was a 2 1/2 to 3" diameter. So it sounds like the small one you are<br />talking about. You said it goes "behind the plate". I'm using the new upgrade kit. Since I didn't see anything obvious, should I look harder, and I should see the location it gets installed? or is it not applicable when doing the upgrade?<br />(I'm not at the boat, and I left the assembly out there, so I'm trying to be as accurate as possible, so if you feel like being more descriptive, that would help.)<br />Thanks, <br />D.
