Impeller water intake hole
MAXXIE
1985 85hp Force motor. On the bottom of the lower unit are the inlet's for water
that leads to the impeller, where you would hook up the "Muffs". It's like a grid cut out of the cast. One of those "bars", (I'll call it), is missing, I'm wondering if there is an easy fix for this. I was going to try to fab up some kind of screen to fit over the hole. I'm just afraid something is going to get sucked into that inlet & jam up the impeller. Any ideas? I'll try to take a pic. of it later & post it up in case I'm not explaining it correctly.
jerryjerry05
Re: Impeller water intake hole
Your chance of picking up something is very small.If you put something over it it will create a restriction and you won't get enough water flow.
I'd leave it alone.Unless you want to get a new case and replace it.J
