SpokaneBassPro
- Apr 20, 2005
- 28
I have a Johnson Super Sea Horse 40 hp and it recently has had some seriously lacking performance. Generally will go about 30 mph and now will go only about 14-15 mph. Drained lower unit gear oil and it was off color and milky. Replaced it and went out on the water, same thing happened after about 25 minutes. I pulled back casing from lower unit off and noticed the rubber gasket halfway down the driveshaft also had the milky fluid all over it. If the impeller or water pump needs replacing how would I go about doing this? I am not sure of the year but some numbers I have pulled off it are 307770, 307759, and 307806AC. Any ideas?
