impeller
lucky7
sierra, mallory, or mercruiser oem?
alpha1 gen2
dont want to save 3 bucks on an inferior part.
i tend to think oem might be the best, does any one have an opinion?
Don S
Re: impeller
Having used all of the ones you listed. OEM, No contest.
Fun Times
Re: impeller
I 100% agree:) Sometimes it seems that when you use aftermarket anything on a boat, It just doesn't seem to work the same as oem.;)
ENSIGN
Re: impeller
Using OME will save you from having alot of headaches!
Bt Doctur
Re: impeller
Considering that most of the manufactures import the OEM parts, exactly what would any difference be besides the price? Mexico,Singapore, Taiwan, etc. all manufacture parts for the industry.
Don S
Re: impeller
The manufacturer (Mercruiser for example) sends out specs for the impeller, as in rubber types, makeup, and tolerances, they also do a lot more inspections to make sure the product meets the specs.
A lot of the aftermarket places may just end up buying what didn't meet specs.
I have gotten impellers that the vanes were so stiff they wouldn't hardly fit in the pump housing. Where the oem impellers go in easily with a slight turn of the shaft, time after time, impeller after impeller.
It's all in the specs and the quality control. Almost is good enough for a lot of the aftermarket stuff, but not good enough for the OEM.
scbackpacker
Re: impeller
Hey Bond-O have you tried one of those impellers? If so are they any better than the OEM?
Re: impeller
Ayuh,... They feel much Better in hand,...
I ran a couple of them for a few years, but lost track of which drives I'd put 'em in,...
Out of the 4 drives I've got laying around, I don't remember which 1s have 'em, other than it ain't the drive On the boat...
cr2k
Re: impeller
Well since Mercury bought out Sierra most of that stuff is coming with MC part numbers on it.
We use a lot of Sierra parts and have had very good luck with them. You just have to know what parts not to buy aftermarket.
artificialreef
Re: impeller
Oh cr#p man, I didnt know the mfgr was important on a rubber part. I guess i am learning the hard way. Newbie boater here and i just bought a couple of water pump repair kits half the price of the oem, sierra and mallory. They are from a co. called Hydra in italy. I ll let you know if they last more than a season. Anyone ever use them? At least theyre not stiff. These being the dreaded 470's i will always be keeping one eye on the temp gauge and one on the bow anyway. Maybe i need to find a chick with a lazy eye to watch both for me. Some guys find that sexy.
