Impeller
springbok
Does anyone know how often you should replace<br />the impeller in an outboard.....or do you wait until it fails?<br /> <br />Thanks
Dhadley
Re: Impeller
Just run it until it fails. How else do you expect dealers to sell pistons?<br /><br />If the motor is new to you, change the entire kit. Not just the impeller. Do a complete cooling system service. Now you have the baseline water pressure. Anytime it starts to change from your baseline its time to find out why. Its not unusual for a pump to last 100 hours. Less if you run in sandy / silty water or you only use the boat once a year.<br /><br />Good luck!
sharkcat
Re: Impeller
You could change it every time the springboks beat the ALL BLACKS or ENGLAND for that matter :D :D but I change mine every 2 seasons & havent had a problem yet.If it fails it will cost you alot of money...
springbok
Re: Impeller
Is it very hard to replace the impeller on a 6hp mercury motor. I'd like to do it myself if possible.
