historymaker78
- Jun 26, 2004
- 16
I just installed and new water pump into my 75 johnson v4 and went to a great deal of care tomake sure (or so I thought) that the shift rod didnt get readjusted. Now when I try to shift into gear it will only grind goin into reverse and never engage. Also the only way I can get forward to engage is to slam it all the way forward which cause me to go into full throttle. If I turned that linkage top a full turn would it make that big a difference? I also unhooked the linkage on the side of the engine and i could get it into forward but it acted as if it was hanging up goin into reverse. #1 thing....I read in aanother forum that you have to almost slam them into gear not just ease them. Does this rule apply for a shiftbox that controls the throttle when you shift. also why would it not go into reverse when i disconnnected the linkage and tryed it by hand. Could that be from not bein able to slam it into gear? I just want any suggestions before I tear the lower unit off tomorrow mornin cuz I think it shifted fine before but I never ran it in the water. If it was fine before (I think) then I must've done somthing.
