in boat circ.pump test?
Berriochoa
have a 1980 volvo aq125b with a 270 sterndrive new t stat and raw water impeller .is it possible to do an in boat test of the circ.pump? boat is overheating
Don S
Re: in boat circ.pump test?
No tests for that pump, I doubt it's your problem anyway. Does your raw water pump water when the engine runs? Is the exhaust manifold plugged up? Is the heat exchanger clean?
When exactly does it overheat? In the water, on plane, in the driveway on muffs?????
Berriochoa
raw water exiting exhaust on muffs. overheats under all conditions
Don S
The only thing that could happen to the circulation pump would be the impeller coming loose from the shaft and not turning.
I would look at the heat exchanger insert. If they get scale covered, the heat will not transfer and will cause an overheat.
You don't mention how hot your engine is running, but the 125's do run at 190?, that is normal.
Berriochoa
starting to suspect gauge. going to tear into heat exch. do u know if there is a kit containing all the o rings , bushings etc...that ill need to replace at reassembly?
Don S
Why don't you get one of those IR Temp guns and find out before you start randomly fixing things that may not be broken. I don't know if there is a kit or not.
Berriochoa
ill try that. should i just temp the tank ,the stat housing or the exchanger ?
Don S
Why don't you check where the gauge sender is located on the engine. Then you will know if your gauge is working properly.
