Hahahaha, dual pissers!!!
Well guys, I have a V4 looper. I am not sure of any areas where it would be easy to add other than the telltale, but I am open to ideas.
There are threads in the tops of both heads, but I dont want to drill into them if I dont have to.
Mine's an original OMC gauge from '82 - tube from the motor straight to the gauge. You can see it working on the left side in this vid clip:
https://www.youtube.com/watch?v=36-azXGY-0g
Likely the gauge had some water in it during winterizing, and it may have frozen. When that happens, the bladder freezes and bends the arm to the needle. Once that happens, your gauge will probably never read right. (as in does not zero out anymore.) also probably reads 3-4 lbs high on top end. I wind up replacing mine ever 4-5 years due to freezing...
And I wonder if the gauge was accurate to start with. What should WOT pressure be on loopers or x-flow V-4s?
