ronboonville
- Jun 6, 2012
- 287
After getting this motor to fire up I can only keep it running by setting on fast or by keep pushing choke button. I dissasembled carb and cleaned but did not remove welch plug. Diagram I found shows an idle screw which looks like it regulates what is called an air tube. So my question is about the proper setting of this screw. Does turning it out richen fuel or lean it out? I beleive the original setting was about a half of turn out. Like I said it runs good at fast setting but dies when I try to slow it down. I am going to try again in a barrel because it emptied a 5 gallon bucket pretty fast. Any insight would be great. Thanks ron
