In Need Of Some Advise On Staniless VS Aluminum Props
StingRay_90V4
I currently have a 1994 StringRay 501 ZP Powered by a 1992 Evinrude 90 HP. The boat works very well and currently is proped with a Aluminum 13 1/4D x 17P propeller. The boat has a good hole shot with the current prop and at wot it does 39-40mph. At 39 mph it sits around 5700rpm. And at 40 mph it sits around 5800-5900 ish rpm. We are looking to replace the old prop with a Stainless steel prop. I have been looking at an OMC 13 1/4 x 17P Stainless Stell prop. But I was Wondering IF I would get a BETTER whole shot and ANY EXTRA top speed. Say at least 1-2 MPH at wot top speed . To maybe hit 41+ mph with a Stainless prop. I have read to much about props in general and I am hoping you guys can help me out with which to buy ? I would like a better whole shot as well as a little better top speed. I was also looking at a 13 3/4 D x 17P prop as well. But I dont know if MAYBE that prop is to big to fit on the 90hp ? One last thing also. The engine is sitting on the BOTTOM whole on the transem. And even my local marine shop told me to raise it up ONE bolt whole. And that would create less gear case drag and gain about 1mph there as well ? Any thoughts on the props as well as the raising of the motor ? Thank you !
jerryjerry05
The cavitation plate should be even with the bottom of the boat, regardless of the hole it's in.
Having a jack plate can make a difference in performance.
The motor should run 5500at wide open.
Not loaded too heavy or too full on fuel.
If your running an alum. 17p now and getting 5900 you can probably us a 17pSS. That will drop the rpms into the right zone.
StingRay_90V4
So what are the advantages of running the SAME diameter and pitch stainless as i was in aluminum ? Would the boat have less top speed or more top speed ? And what affect on the whole shot would it have ?
As for the cavitation plate. It is roughly an inch BELOW the bottom of the boat when the motor is level. Half trim kinda thing i guess.
your aluminum prop does flex a bit at higher RPM compared to the stainless. Stainless will drop your RPM's a bit while raising your speed because it will get just a bit more bite. Holeshot wold probably be about the same. kind of hard to get a better holeshot and a higher top speed unless your looking at ventilated props or a bigger motor
based on your motor being below the bottom of the boat, I would suggest it come up about an inch.
F_R
Your aluminum prop probably isn't cupped is it? And the stainless ones usually are. That cupping generally will give just a bit more top speed and may reduce RPM's just a tad. In addition, stainless props are thinner and stronger, which improves performance. So, we are talking generalities here and only a mile or two in speed. Do you run in skinny water where you boat? Aluminum props are very prone to damage (loss of performance) if you run them across the bottom. Stainless ones are much stronger and will outlast several aluminum ones under such conditions. And cost more. Yeah, raise that motor a notch. Running it higher is another reason to run a cupped prop.
emdsapmgr
Posts 4,5 are right on target. If the anti-ventilation plate is below the bottom of the boat, it may be dragging in the water when on plane. The water streaming from under the boat's transom needs to flow just under that anti-ventilation plate. If that plate is underwater, you will have excess spray, (drag) poor performance and lousy fuel economy.
littlerayray
You don't need a stainless prop unless your in salt or brackish water your boat isn't pushing enough hp to distort the aluminum
StingRay_90V4
Im confused now... Lol... Everyone tenda to say a good stainless on any hp boat will give some performance advantage at top end and gets on plane faster ? I was looking at a solas titan 13.25dx17p stainless stainless prop. Or a old used stanless the same sixe off ebay for $100 . But it appears to a tad older as well as a few small dings out of a few of the blades
StingRay_90V4
So wouldni just stick with an aluminum prop? Or isbthere a bit more performance to be had in switching to a stainless unit on a 90hp v4 ?
bob johnson
what is 2-4 mph at 40 mph??? does that make a difference??? Ill tell you this the day you clip a rock with the SS you will wish you have an aluminum one!!
I thought( 5 years ago) the SS prop on my 115 gave me more speed and more rpm........but once I hit a rock... and had to rebuild the lower unit.(LOTS OF $$$$), I said 6 aluminum props are cheaper than that!!!!!!!!!!!!....
bob
LuckDay
I fully agree with Bob Johnson - he must know what he is talking about with the last name "Johnson" on an Johnson Evenrude forum. Stingray, I too am struggling with the possibility of changing a prop from the exact same size alum you run on my 110hp Johnson to S/S or possibly a 4 blade s/s. I agree with the lower end and hitting a rock and BAM! there goes the lower leg. With the aluminum it is still a nasty grind/ screech and possible stall. But the gear case for the most part stays in one piece. Always carry a spare prop, nut and washer kit. Even a used damaged prop as a back up is better than trying to walk home up river.
Joe
bruceb58
Stainless props have thinner blades so you will see a performance increase just because of that...less drag.
Fun Times
http://www.killcaremarina.com.au/index.php/everything-you-need-to-know-about-propellers.html
Everything You Need to Know About Propellers
In determining boat performance, propellers are second in importance only to the power available from the engine itself. Without the propeller's thrust, nothing happens.
Your boat's propeller affects every phase of performance - handling, riding, comfort, speed, acceleration, engine life, fuel economy and safety.
Like tires on a car, the propeller conducts the power from the engine to the "road". Your propeller is the primary connection between your engine and the water. Which propeller or propellers you select to make that connection is critical to achieving optimum boat performance.
This article provides even the novice boater a solid understanding of propellers. However, some of the information presented here is also very technical. [h=2]BASIC PROPELLER PARTS[/h] The first step to understanding propellers and how they work is familiarizing yourself with the basic parts of a propeller. (Figure 2-1) [h=3]
Basic Propeller Parts[/h] A. Blade Tip
The maximum reach of the blade from the center of the propeller hub. It separates the leading edge from the trailing edge.
B. Leading Edge
That part of the blade nearest the boat, which first cuts through the water. It extends from the hub to the tip.
C. Trailing Edge
That part of the blade farthest from the boat, the edge from which the water leaves the blade. It extends from the tip to the hub (near the diffuser ring on through-hub exhaust propellers).
D. Cup
A small curve or lip on the trailing edge of the blade, permitting the propeller to hold water better and normally adding about 1/2" (12.7 mm) to 1" (25.4 mm) of pitch.
E. Blade Face
That side of the blade facing away from the boat, known as the positive pressure side of the blade.
F. Blade Back
The side of the blade facing the boat, known as the negative pressure (or suction) side of the blade.
G. Blade Root
The point at which the blade attaches to the hub.
H. Inner Hub
(Figures 2-2 and 2-3). The forward end of the inner hub is the metal surface which generally transmits the propeller thrust through the forward thrust hub to the propeller shaft and in turn, eventually to the boat.
I. Outer Hub
For through-hub exhaust propellers. The exterior surface is in direct contact with the water. The blades are attached to the exterior surface. Its inner surface is in contact with the exhaust passage and with the ribs which attach the outer hub to the inner hub.
J. Ribs
For through-hub exhaust propellers. The connections between the inner and outer hub. There are usually three ribs, occasionally two, four, or five. The ribs are usually either parallel to the propeller shaft ("straight"), or parallel to the blades ("helical").
K. Rubber Hub
Rubber molded to an inner splined hub to protect the propeller drive system from impact damage and to flex when shifting the engine, to relieve the normal shift shock that occurs between the gear and clutch mechanism - generally used with low horsepower applications.
L. Diffuser Ring
Aids in reducing exhaust back pressure and in preventing exhaust gas from feeding back into propeller blades.
M. Exhaust Passage
For through-hub exhaust propellers. The hollow area between the inner hub and the outer hub through which engine exhaust gases are discharged into the water. In some stern drive installations using a through-transom exhaust system, this passage carries air. [h=3]Hub Configurations[/h] At the center of the propeller is the hub. If exhaust gases are discharged into the water through the hub, the propeller is called a through-hub exhaust propeller.
If the exhaust gases are not discharged into the water through a passage in the hub, but rather over the hub, the propeller is called an over-the-hub exhaust propeller. This design allows the engine to wind up quickly as the propeller bites into water and exhaust. Top speed may improve due to the reduction in drag associated with the outer hub, but generally acceleration suffers slightly.
There are three types of hubs: one with a rubber hub (round or square) (Figure 2-2), the second with a hub system (Figure 2-3), and a solid hub (Figure 2-4) which are generally used on racing engines. [h=2]HOW PROPELLERS WORK[/h] [h=3]The "Push/Pull" Concept[/h] To understand this concept, let us freeze a propeller just at the point where one of the blades is projecting directly out of the page (Figure 3-1). This is a right-hand rotation propeller, whose projecting blade is rotating from top to bottom and is moving from left to right. As the blade in this discussion rotates or moves downward, it pushes water down and back as is done by your hand when swimming. At the same time, water must rush in behind the blade to fill the space left by the downward moving blade. This results in a pressure differential between the two sides of the blade: a positive pressure, or pushing effect, on the underside and a negative pressure, or pulling effect, on the top side. This action, of course, occurs on all the blades around the fall circle of rotation as the engine rotates the propeller. So the propeller is both pushing and being pulled through the water. [h=3]Thrust/Momentum[/h]
These pressures cause water to be drawn into the propeller from in front and accelerated out the back, just as a household fan pulls air in from behind it and blows it out toward you (Figure 3-2).
The marine propeller draws or pulls water in from its front end through an imaginary cylinder a little larger than the propeller diameter (Figure 3-3). The front end of the propeller is the end that faces the boat. As the propeller spins, water accelerates through it, creating a jet stream of higher-velocity water behind the propeller. This exiting water jet is smaller in diameter than the actual diameter of the propeller.
This water jet action of pulling water in and pushing it out at a higher velocity adds momentum to the water. This change in momentum or acceleration of the water results in a force which we can call thrust.
[h=2]
PROPELLER TERMINOLOGY[/h] There are a variety of terms used to describe propeller characteristics as well as performance attributes. It is important that you have a good understanding of them, as detailed here. [h=3]Diameter[/h] Diameter is the distance across the circle made by the blade tips as the propeller rotates (Figure 4-1).
Diameter is determined primarily by the RPM at which the propeller will be turning and the amount of power that will be delivered to the propeller through the shafts and gears. The degree to which the propeller may operate in a partially surfaced condition, as well as the intended forward velocity, will also play a role in determining the most desirable diameter. Within a given propeller line, the diameter usually increases for propellers used on slower boats and decreases for faster boats. If all other variables remain constant, diameter will increase as power increases; diameter will increase as propeller RPM decreases (slower powerhead or engine speed and/or more gear reduction); and diameter should increase as propeller surfacing increases. [h=3]Pitch[/h]
Pitch is the distance that a propeller would move in one revolution if it were moving through a soft solid, like a screw in wood (Figure 4-2).
When a propeller is identified as 13 3/4 x 21, it has a 13 3/4" (35 cm) diameter with 21" (53 cm) of pitch. Theoretically, this propeller would move forward 21" in one revolution.
Pitch is measured on the face of the blade (Figure 4-4). A number of factors can cause the actual pitch of a propeller to vary from the advertised pitch stamped on it. Minor distortion may have occurred during the casting and cooling process. Adjustments or modifications may have been made by propeller repair stations. And finally, undetected damage may have altered the pitch.
There are two common types of pitch: constant (also called "true" or "flat") pitch and progressive pitch (Figure 4-3). Constant pitch means the pitch is the same at all points from the leading edge to the trailing edge. Progressive pitch (also called blade "camber") starts low at the leading edge and progressively increases to the trailing edge. The pitch number assigned (for example, 21") is the average pitch over the entire blade.
Progressive pitch improves performance when forward and rotational speed are high and/or the propeller is operating high enough to break the water surface. It is commonly used on mid- to high-horsepower propellers.
Pitch is rather like another set of gears. For a given engine that wants to run at a given RPM, the faster the boat can go, the higher the pitch you need. If you select too low a pitch, the engine RPM will run too high (above the top of the recommended limit), putting an undesirable higher stress on many moving parts. You may have a great acceleration but your top speed will probably suffer and your propeller efficiency will definitely suffer. If you select too high a pitch you will force your engine to lug at a low RPM (below the recommended range) which is generally at a higher torque level and can be very damaging to your engine. Top speed may not suffer too much, but acceleration will be seriously reduced. [h=3]Rake[/h] When a propeller blade is examined on a cut extending directly through the center of the hub, as in Figure 4-4, the face side of the cross section of the cut blade relative to a plane that is perpendicular to the propeller axis would represent blade rake (Figures 4-5, 4-6, and 4-7).
If the face of the blade is perpendicular to the propeller hub (Figure 4-5), the propeller has zero degree rake. As the blade slants back toward the aft end of the propeller, blade rake increases (Figure 4-6). With standard propellers, the rake angle varies from -5? to 20?. Basic propellers for outboard engines and stern drives commonly have around 15? of rake. Higher-raked (high-performance) propellers often have progressive rake which may go as high as 300 at the blade tip.
Rake is either flat (straight) as shown in Figures 4-5 and 4-6, or curved (progressive) as shown in Figure 4-7.
A higher rake angle generally improves the ability of the propeller to operate in a cavitating or ventilating situation, such as when the blades break the water's surface. With such surfacing operation, higher blade rake can better hold the water as it is being thrown off into the air by centrifugal force, and in doing so, creates more thrust than a similar but lower raked propeller. On lighter, faster boats, with a higher engine or drive transom height, higher rake often will increase performance by holding the bow of the boat higher, resulting in higher boat speed due to less hull drag.
However, with some very light, fast boats, higher rake can cause too much bow lift, making these boats more flighty or less stable, in which case a more moderately raked propeller would be a better choice. [h=3]
Cupping[/h] When the trailing edge of the blade is formed or cast with an edge curl (away from the boat), it is said to have a cup (Figure 4-8). Originally, cupping was done to gain the same benefits as just described for progressive pitch and curved or higher rake. However, cupping benefits are so desirable that nearly all modem recreational, high-performance or racing propellers contain some degree of cup.
Cupping usually will reduce full-throttle engine speed about 150 to 300 RPM below the same pitch propeller with no cup. A propeller repair shop can increase or decrease cup to alter engine RPM to meet specific operating requirements on most propellers.
For a cup to be most effective, it should be completely concave (on the face or pressure side of the blade) and finish with a sharp trailing edge. Any convex rounding of the trailing edge of the cup, on the pressure side, detracts from its effectiveness.
Cupping is usually of little value on propellers used in heavy-duty or work applications where the propeller remains fully submerged. [h=4]Importance of Cup Location[/h] Using a round-bladed propeller as an example, if the cupped area intersects pitch lines, as in Figure 4-9, it will increase blade pitch. Cupping in this area will reduce RPM by adding pitch. It will also protect somewhat against propeller "blowout" (see Cavitation, below). If the cup is placed so that it interests rake lines, Figure 4-10, it then has the effect of increasing rake (see Rake, above). There is clearly some overlap where cup effects both pitch and rake.
In some cases, adding a normal cup has reduced engine RPM by an unusually high number, as much as 1000 RPM. This "blown out," a situation not uncommon and often undetected until a cupped propeller is tried. A partially blown-out propeller has a mushy, somewhat unresponsive feel, and may produce excessive propeller spray. An accurate slip calculation (see Slip, below) can be beneficial here. Slip will generally jump from its normal 10% to 15% to over 20% for a partially blown-out propeller (on an average - to lightweight boat).
Adjusting the cup on a cleaver-style propeller is more difficult. Since the trailing edge is very thick and runs straight out on a rake line, any adjustment will have far less effect on altering rake (Figure 4-11).
The added pitch created by the cup can be reduced substantially by filing or grinding away some of the cup. At the same time, rake can be altered slightly. For less rake, decrease the cup in the area close to the tip. For more rake, reduce the cup in the area close to the hub. Obviously, any cup reduction will also result in an RPM increase. [h=3]
Rotation ("Hand")[/h] There are right-hand rotating (RH) and left-hand rotating (LH) propellers (Figure 4-12). Most outboard and stern drive propellers are right-hand rotation.
To recognize a right-hand propeller, observe the prop from a position shown in Figure 4-12 (resting on either end of the hub is OK) and note that the right-hand propeller blade slants from lower left to upper right. A left-hand propeller will have the opposite slant-from lower right to upper left. The blade slopes or climbs up in the direction of rotation. A right-hand rotation propeller has the same basic blade slope as the threads on a common right-hand screw.
Another method of recognition is to observe the propeller rotating in forward gear from behind the boat. A right-hand propeller turns clockwise; a left-hand propeller turns counter-clockwise. [h=3]Number of Blades[/h] A single-blade propeller would be the most efficient - if the vibration could be tolerated. So, to get an acceptable level of balance with much less vibration, a two-bladed propeller, practically speaking, is the most efficient. As blades are added, efficiency decreases, but so does the vibration level (Figure 4-13). Most propellers are made with three blades as a compromise for vibration, convenient size, efficiency, and cost. The efficiency difference between a two- and a three-bladed propeller is considered less significant than the vibrational difference. Nearly all racing propellers are presently either three- or four-bladed.
In recent years, with the growing frequency of propellers being run at an increased height (surfaced), four- and five- bladed props have become more popular. They suppress the higher level of vibration and improve acceleration by putting more blade area into the water. They can also help to make the rake more effective in lifting the bow of the boat for added speed.
[h=3]Blade Thickness[/h]
Like a tree limb growing from a tree trunk, a blade is thickest at the point where it meets the hub (blade root). As the blade moves out from the hub to the tip, it becomes thinner (Figure 4-14). The basic reason for this is that, as with any cantilever beam, the load that any blade or beam section must support is the load on the blade or beam between that section and the tip of the blade. Thus, at the tip there is zero load requiring zero thickness. However, to be practical, a given minimum edge thickness is chosen for a given propeller material and type of use.
Since there is only so much power available, blades should be as thin as practical (considering the strength of their material) because it takes more power to push a thick blade through the water than a thin blade.
But what about the thickness variation from the leading to trailing edge? When viewing a common blade cutaway at a given radius from the center of a constant pitch-propeller (Figure 4-15), an approximate flat surface will be observed on the positive (pressure) side and a circular arc surface on the negative (suction) side, with the thickest point in the center. Edges usually are .06" to .08" (1.5 mm to 2.0 mm) thick for aluminum propellers, thinner for stainless steel.
For propellers intended to run partially surfaced, as in racing applications, the "cleaver" blade shape (see Figure 4-14) is popular. Its blade section is usually a wedge. Blades with a thick trailing edge such as this should only be run surfaced. When they are run deep, where surface air can't ventilate the low-pressure cavitation pockets formed behind the thick trailing edge, they are less efficient. [h=3]
Blade Contour[/h] Contour is the shape of the blades as viewed from directly over the blade face or back. The contour is generally completely rounded, commonly called "round-eared" or shaped with a straight trailing edge, commonly called a "cleaver." [h=3]Skew[/h] A blade that is swept back versus a blade that is radially symmetrical in contour is said to have skew (Figure 4-16). Considerable skew (sweep back) is helpful in allowing a propeller to more easily shed weeds. Higher skew on a surfacing application reduce the pounding vibration of a propeller blade re-entering the water. [h=3]Ventilation[/h] Ventilation occurs when air from the water's surface or exhaust gases from the exhaust outlet are drawn into the propeller blades (Figure 4-17).
The normal water load is reduced and the propeller over-revs, losing much of its thrust; however, as the propeller momentarily over-revs, this brings on massive cavitation (see Cavitation, following), which can further "unload" the propeller and stop all forward thrust. It continues until the propeller is slowed down enough to allow the bubbles to surface, and the original cause of cavitation is eliminated. This action most often occurs in turns, particularly when trying to plane in a sharp turn or with an excessively trimmed-out engine or drive unit.
Outboard engines and stern drive units are designed with a large "antiventilation" plate cast integrally into the gear housing (also commonly called the "gearcase") directly above the propeller (Figure 4-18). This plate is frequently, but incorrectly, referred to as a "cavitation" or "anticavitation" plate. The purpose of this plate is to eliminate or reduce the possibility of air being drawn from the surface into the negative pressure side of the propeller blades.
For improved engine and boat performance, most propellers feature a hub design with a flared trailing edge or "diffuser ring." This assists exhaust gas flow and provides a high-pressure barrier that helps prevent exhaust gases from feeding back into the negative pressure side of the blades (Figure 4-19), which is another form of ventilation. [h=3]Cavitation[/h]
We all know that water boils at 212?F (100?C) at normal sea-level atmospheric pressure. But water also boils at room temperature if the atmospheric pressure is low enough.
As a shape passes through water at an increasing speed, the pressure that holds the water to the sides and back of the shape is lowered. Depending upon the water temperature, when the pressure reaches a sufficiently low level, boiling (i.e., the formation of water vapor) will begin. This occurs most often on a propeller near the leading edge of the blade. When speed is reduced and the pressure goes up, boiling will subside. As the water vapor bubbles move downstream into a high- pressure region that won't sustain boiling, they collapse (condense back to liquid). The collapsing action, or implosion, of the bubbles releases energy that chips away at the blades, causing a "cavitation burn" or erosion of the metal (Figure 4-20).
The initial cause of the low pressure may be nicks in the leading edge, too much cup, sharp leading edge comers, improper polishing, or, sometimes, poor blade design. Massive cavitation by itself is rare, and it usually is caused by a propeller that is severely bent or has had its blade tips broken off resulting in a propeller that is far too small in diameter for the engine. (See Ventilation, above, for another common cause.)
The cross section of a propeller blade in Figure 4-21 shows an example of one cause of cavitation. In this instance, a sharp leading edge produces cavitation and resulting cavitation burn as the bubbles condense further back on the blade face. Such cavitation burn can usually be corrected by repairing or rounding off the leading edge directly in front of the burn. Cavitation and cavitation burns can also form on the side of your gearcase. This will almost always be the result of a sharp edge directly ahead of the burn. Rounding off the sharp edge will usually eliminate the problem. [h=3]Angle of Attack[/h] To further understand how propellers work, it is important to appreciate the concept of "angle of attack." (This concept is also important in understanding propeller slip, detailed below.) To do so, it is helpful to compare how a propeller blade works to how an airplane wing functions. The wing of an airplane and its ability to carry the weight of the plane by providing lift is very similar to the spiraling travel of a propeller blade, which provides thrust.
If a wing with symmetrical airfoil (Figures 4-22 and 4-23) is moved through the air so that air moves symmetrically above and below the wing, there is equal pressure above and below resulting in no "lift." The wing is said to be operating at zero degree (0?) angle of attack.
With an angle of attack (Figures 4-24 and 4-25), there is a pressure change or difference above and below the wing which creates lift: negative (lower) pressure on the top and positive (higher) pressure below.
Although it is clear that the airplane wing and the propeller blade move through air and water respectively, marine engineers prefer to talk about the situation in terms of the water moving into the blade. Allowed that freedom, consider Figures 4-26 and 4-27, which show the same angle of attack phenomenon, only in this case, for the propeller blade.
Figure 4-26 shows blades operating at zero angle of attack. This creates no positive or negative pressures on the blade; therefore, there can be no lift or thrust. Blades operating with some angle of attack (Figure 4-27) create a negative (lower or pulling) pressure on one side and a positive (higher or pushing) pressure on the other side. The pressure difference causes lift at approximately right angles to the blade surface. Lift can be divided into a thrust component in the direction of travel and a torque component in the opposite direction of propeller rotation.
[h=3]Slip[/h] Slip is the most misunderstood of all propeller terms, probably because it sounds like something undesirable. Slip is not a measure of propeller efficiency (see Efficiency, below). Rather, slip is the difference between actual and theoretical travel resulting from a necessary propeller blade angle of attack (see Angle of Attack, above). For example, in Figure 4-28, a 10" propeller actually advances only 8-1/2" in one revolution. Eight and one-half inches is 85% of 10", leaving a slip of 15%. If the blade had no angle of attack, there would be no slip; but, of course, there would be no positive and negative pressure created on the blades and, therefore, there would be no thrust.
To create thrust there must be some angle of attack or slip. The objective of propeller design is to achieve the right amount of slip or angle of attack, which is around 40, give or take a degree (Figure 4-30). This is accomplished by matching the right amount of blade diameter and blade area to the existing engine horsepower and propeller shaft RPM. Too much diameter and/or blade area will lower slip but will also lower propeller efficiency, resulting in reduced performance. Figure 4-29 illustrates this point.
[h=2]TYPES OF PROPELLERS[/h] [h=3]General Propeller Types[/h] Propellers are classified by construction - the type of material from which they're made, such as aluminum or stainless steel and by design. Pleasure boat propellers can be divided into six general types: basic aluminum, basic stainless steel, high-reverse thrust, cleaver-style, chopper-style, and other high-performance stainless steel propellers. [h=3]General Propeller Blade Types[/h] Propellers differ greatly in appearance because of the shape of their blades. However, there really are only three general blade types.
Conventional
The conventional, sometimes called round-eared, blade type is that seen on most propellers (Figure 6-1). It has a rounded con?tour, has a slight amount of sweep back or skew and may be of a variety of shapes based on the type and application of propeller. It is designed to run fully submerged but can be run slightly surfaced with light loads in some cases.
Weedless
Propellers vary in their degree of weedlessness. That is, a cer?tain amount of weedlessness is designed into most propellers. But the blade type that is most weedless, and therefore classed as such, is a rounded blade with a high degree of skew; that is, the leading edge is swept back to a high degree leaving no weed-snagging leading edge projections (Figure 6-2).
Even very weedless propellers can appear to be entangled in a ball of weeds which are, in fact, caught on the leading edge of the gear housing strut and torpedo. The rotating blades often create a tight weed doughnut wrapped around the forward end of the propeller's outer hub. Generally, these weeds will shed with reverse propeller rotation or, sometimes, a short burst of high-speed operation. A significant weed ball, however, can cause so much cavitation that it will prevent the generation of sufficient thrust to achieve planing.
Cleaver
"Cleaver" is a name applied for many years to a propeller whose blades have their trailing edge cut on a straight line, generally on a rake line (Figure 6-3). Often accompanying this blade shape is a blade cross section that looks more or less like a wedge; that is, the leading edge is very thin and sharp, while the trailing edge is the thickest point on a pitch line. This style is best suited for elevated engine installations which allow the propeller blades to break the water surface (called surfacing).
Frank Acampora
All that prop theory is very good for understanding basic principles BUT: The fact remains that different brand stainless and aluminum perform differently on a given engine and you have no way of knowing which will be best without testing. IF you can find someone with the same hull and engine as your and using a different prop you can learn something from them.
drpepper68
bob
I dont understand, how is an aluminum prop going to save your lower end? It just takes the brunt of the force where as a SS prop transfers all the energy to the shaft? Still learning...
bruceb58
Aluminum is softer. The blades will "give" where the blades of the stainless steel prop won't.
I just make sure I don't hit any rocks!
