Inboard replacing
Bwayne121
I have a 2005 marish sx19 with the 4.3 I was wondering if I can drop the 7.4 bravo in it that I have?
QBhoy
Is there room for it ? Then there is the mounts to change and glass in. Then there is the load of work to change the alpha one to bravo and all that involves with transom work etc etc. Then there is the huge weight difference between a 4.3 and a big block 7.4. I’d think it would be a little too much perhaps.
achris
More fish than mountain goat
Simple answer is 'yes'... But you'll absolutely need to change the drive too, and that means a complete package change (engine, drive AND transom assembly).
However, unless you are racing that boat (and it's NOT a racing boat) or you have a death wish, I have to ask, why?
The 4.3 should be pushing it up around the 50 knot mark. Apart from the extra weight, around 150kg, that about 2 average people (or one average American ;)) Just trying to drive that boat at 'normal' speeds will be problematic. The revs at 20 knots will be so low as to be outside the engine power band, and that means way less power where you really want it.... Yeah, it'll be a handful...
Chris....
I wouldnt put a porkchop motor in a 19 foot boat
If you want speed, a 6.2 / Alpha will nearly flip the boat
Rick Stephens
A 383 is the ticket. Big blocks great in big boats. Stroker small blocks belong in teeny weenie hole in water. More git'eup than you probably need even. And you can stay with an Alpha drive, albeit one with taller gears.
achris
Even the 'least powerful' 383 is up around 320hp. With that power in that boat, he'll be looking at AT LEAST 60 knots, and that means a bit of 'air time'... Say goodbye to an alpha. And even with 1.47 gears, he's going to need a 23" or 25" prop. And 60 knots is the limit on an alpha before blow-out. All in all, this is getting silly.
Chris.....
Rick Stephens
Chris.....
Ok, ok. OP is probably already installing that big block to add drag. Seems he posted and disappeared anyway.
achris
I really want a 6.2 mpi for my boat. Just can’t find one over here. Hens teeth unfortunately.
Build one. Take a standard 350 (5.7L) and put a stroker kit in it. Using the same heads and cam it'll take it from 260hp (non Vortex) to around 310hp. If you add Vortex heads and a nice cam, getting to 360hp is fairly easy.
QBhoy
Thought about it Chris...but the stubborn bit in me wants to stay mpi these days. no doubt the easy way is to do just as you say...many have told me likewise. but I just want to stick with mpi for the economy and smart craft function too. My own current mpi in the boat now is a great thing. She was fitted with a cam as a package when new, but as mentioned before, its just not well suited all round, with the ecu and fuelling just as original. lots of power up top, but almost lazy down low. So if I run a prop that will see her perform at her quickest at around 67 mph gps...that same prop will mean that she will hardly plane with much more than me onboard, not to mention the terrible struggle she has being happy at slower cruising speeds and just general all round use. So most often, I run less pitch that will see her happy cruising and planing, but will then of course hit the limiter at the top end all too easy...
I assume I may have around or close to 300HP just now, so not only the extra 20hp is appealing..but most of all, the extra low down power a 6.2 would have, is most of all what attracts me. The boat can definitely handle more power easily. The 6.2 would drop straight in and marry to the lovely corsa marine system too. The search continues!
build it and have the ECM re-flashed
rotating assemblies are under $1000. ECM re-flash is $400, better cam kit about $400, head work, about $200
BTW, no economy gains for MPI/DFI/Carb
achris
Was going to say ^^^, especially the bits about economy and re-flashing.
achris
....I assume I may have around or close to 300HP just now, so not only the extra 20hp is appealing..but most of all, the extra low down power a 6.2 would have, is most of all what attracts me....
Which means you aready have Vortec heads. With JUST the stroker kit, (and the cam you currently have) I think you'd be looking at around 360hp, and a metric s..t-ton more torque in the mid-range.
Just do it! :cool:
Chris......
QBhoy
I haven't yet been aware of anyone here that can re map the ecu on these. If that was an option, I would 100% do this to the engine I have now. It over fuels at low rpm and likely under fuels near the top...or not as good as it could be. One good thing about the set up is the very guttural sound she makes at idle. Lovely noise from her. very different sounding from any other normal SB v8 I've heard. rough sounding lumpy primeval noise. Lovely.
achris
I haven't yet been aware of anyone here that can re map the ecu on these. If that was an option, I would 100% do this to the engine I have now....
Postage to USA to Whipple or any of the other ECU repairers/remappers is easy and cheap. Talk to them and see what's involved.
(I think you're west coast of Scotland, yes?)
Chris.......
QBhoy
Chris.......
That's right Chris. Worth a thought then. Appreciate the advice.
Scott06
Just do it! :cool:
Chris......
If i recall he has a 5.0 mpi, 5.0 block i dont think can get bored out to 5.7 bore. NOt sure if heads are same as 5.7 suspect smaller 5.0 bore takes different valves but could be wrong …
