I have the Arco 70200 that is used as a replacement when the 70100 inventory is exhausted. The 7200 is a high performance gear reduction starter. Hence, why it looks so different. Here is what the supplied directions state: 1) Remove the starter cable from the starter relay and re-install on the same terminal post as the battery positive cable. 2) Attach the 12GA red wire to the starter relay post where the starter cable was removed. 3) Attach the other end of the starter cable to the large post on the starter solenoid (mounted on the new starter). 4) Attach the other end of the 12GA wire to the spade terminal on the starter relay (mounted on the new starter). 5) Installation complete. I followed these directions exactly, but when I turned the key on to where just accessories should come on the engine cranks over any suggestions would be great
