Incorrect link in How To Stickies.
Simoniz
In the section, Adults Only/Mercruiser Information/HowTo/Replacing Merc Alpha Style Impellor, there are 2 links, One entitled MC1 to Alpha 1 up to and including 1990, and Alpha 1 Gen II only 1991 to present.
Unfortunately both links lead to the same info, that for the MC1 to Alpha, ie there is no info there for the Gen II drives.
Just thought Id point it out in case its an easy fix for someone to put the correct info under the Gen II link.
Cheers
Fun Times
Re: Incorrect link in How To Stickies.
Thank you Simoniz for pointing out the error. I could see where the error was made but all the past links that were correct were no longer available to us. They were gone in cyberspace. Luckily Don also attached thumbnails to the parts of the service manual he wanted everyone to follow. So now all anyone has to do is click and open the attached thumbnail highlighted in red. I have made the changes to the notes next to/above the thumbnail found in the stickies. Thanks again.:)
