Greetings!
I have had very good luck with advice here in the past.
My good old Evinrude ('71 100 hp) has been giving me lots of headaches this last summer. I thought I had them all fixed, and the other day took it to the lake for a last ride of the season. Everything was perfect, except one item- WOT. Every thing was fine at 4500 RPM, [steady tach, steady sound, steady speed] but at full power, it only climbed to 4900, the tach was bouncing and the motor sounded rough like an intermittent miss. [it had been running nicely at 5500 a few years ago before a slew of problems and issues]
I do not think it is fuel, as it occurred on two tanks, both with fresh gas. However, it could be in the carbs. Can I get and replace just the high speed orifices? Would running seafoam clean the carbs?
I don't think it is the spark plugs as they were replace in mid summer. If I pull the plugs, what should I look for?
I do not think it is the prop because that would affect RPM but would it also cause the engine to run rough?
Any suggestions/ recommendations/ possibilities are appreciated.
Thanks for all your help!
PS- I also had hooked up the digital mutimeter to check voltage on the run. It seemed to constantly grow, and after 20 minutes was at 17.5V. I was just reading a thread here where it was recommended to install a regulator. Where would I get such a item and where is it mounted?
