Increasing Casting Distance
Bassn7
I want to make longer casts when throwing top water lures. Will I add much distance by decreasing line diameter and going to braid?
dingbat
Rodsmith, competitive angler and caster
4. Increase rod length
3. Reduce friction in the guides (reduction in line diameter. Better designed rod)
2. Reduce friction of reel spool
1. Improve your technique
Practice Practice Practice
Until you reach a plateau, practice will overcome all of the above
88evinrude
To add on top of what he said sometimes a bearing upgrade helps.
