Indmar Vortec Intake Manifold ok for MerCruiser application?
NormRinker
Will an intake manifold (Vortec) from Indmar work ok in my MerCruiser (Vortec also) application?
I'd like to switch over to the 4 barrel intake and carburetor set-up from 2 barrel, and I think I can get an Indmar one for a good price.
Thanks, Norm
Re: Indmar Vortec Intake Manifold ok for MerCruiser application?
It Should be a Direct Swap,.........
But there's Always the chance that a Bolt Hole you Need isn't there.......
NormRinker
Hey Bondo,
Thanks yet again for your answer to another thread of mine to help me out. :)
I think it's time for me to run out into the garage to study my original 2 barrel intake manifold. See where all the tapped holes are, and stuff like that to see what the differences are there on that aspect of the swap-over..
BUT...
Here are a couple of pictures showing the differences between "Indmar" and "MerCruiser" 4 barrel intake manifolds. Both are for Vortec.. Please take a real close look up front on the manifolds..
Indmar: http://www.michiganmotorz.com/popup_image.php?pID=113
MerCruiser: http://www.michiganmotorz.com/popup_image3.php?pID=114
Notice how the Indmar one has two tapped bosses sticking out horizontally right in the front? Also notice how the Indmar one has it's thermostat opening located really up forward past the first intake manifold to cylinder head bolt? Comparing with the MerCruiser one where the thermostat housing bolts line up with the second intake to head bolt back from the first one in the front.
What do you think of the differences I caught while studying the pictures? Wouldn't the Indmar one interfere with anything espically the thermostat housing location differences between both manifolds?
Thanks, Norm
NormRinker
I did some more research on the available Vortec intake manifold options, and I have decided against the Indmar intake manifold now. It will fit, but I might run into obstacles. I saw a new one on Ebay for real cheap, but I missed the auction anyway.
