Re: Infestation
Just remember, Carpenter ants are extremely finicky when it comes to baits. You can have one colony that will take a bait, and another colony that will walk by. Also, the foods that are desirable change through the year. In the spring they search out high energy foods like honey, hummingbird feeders, orange peels, etc. As you get into summer they switch to eating other insects, meats, and the sweets are no longer desirable. Terro usually does not work on Carpenter Ants, nor does any other store bought bait. Boric acid baits can work, but the percentage of chemical must be very small or the ants die before getting the food to the colony.<br /><br />Ants cannot eat what they find, it must all be brought to the larvae in the colony. the larvae is the only stage of ant development that can eat any foraged food. This food is converted to a liquid that is digested by the rest of the colony. When an ant wants to feed, it palpates the larvae which then regurgitates the liquid to the ant. The process is called throsolaxis. All current carpenter ant treatment techniques take advantage of this by either using a low dosage residual chemical that is physically brought in and transfred through touch or through the feeding cycle. Another thing to remember about baits is that ants cache their food, and it can be weeks before they even get to the bait that has been cached. If the baited food goes bad by decaying, they will remove it from the nest without eating it. What I have done with boats that have Carpenter ants is to gas the colony site directly using a machine that uses pure pyrethriums (vs the .005 percent pyrethriums found in over the counter products). You can always fully enclose the boat with its cover, open all hatches, and set off some bombs. The chemical in the bombs shouls be enough, and it breaks down with no residual very quickly, so you don't have contamination in your boat. Good luck... <br /><br />As far as spiders go, I spray my boat in all hatches, under the gunnels, anywhere that is out of site or touch, and it works for the most part as they walk through it eventually. Of course, I do this for a living so my stuff is going to be a bit better than over the counter...
