inflatable HP for kids - advice wanted
carljh
Hi,<br /><br />OK not exactly the usual type of question on here BUT...<br /><br />What HP is required for a teenager in an inflatable to pull another teenager on a ring/tube. Does not need to be a dangersous speed but must be enjoyable?
CATransplant
Re: inflatable HP for kids - advice wanted
What inflatable? What's the horsepower rating for the boat? It's impossible to answer your question without more information.<br /><br />The more information you can provide, the better able the folks here will be to help you.<br /><br />I have an inflatable that's limited to 3 hp. It won't tow anything. Yours may be different.
crazy charlie
I would say the mininum would be an 8hp or a 9.9 with the correct prop to pull.But as CAT. mentioned,the size of the boat has a lot to do with it and the size of the 2 teenagers.
BF
Hiya,<br /><br />I'm not sure how experienced with boats and tubing/skiing or whatever... but a word of caution, it's not just the speed that is the safety concern.<br /><br />Anytime you have someone in the water close to an outboard motor you have a major safety issue. I have seen many times that people not familiar with boats don't give the prop in the water the proper respect. I've seen people climb into the boat by climbing on the cavitation plate of a running outboard (thought it was safe because it was in neutral)... as they are clawing at the sides of the motor (= gear shift) looking for a hand hold!! I've seen someone say "ok start it up" while they are in the water and literally touching the outboard!<br /><br />How these people manage to not mangle themselves is beyond me. Or maybe Darwin is at work, and their boating experiences end badly (?).<br /><br />So, whatever outboard you have on the inflatable, make sure your teens know that the motor should be shut off anytime there is a swimmer in the water close to the boat.... When it's time to start, either push the tuber away or have them paddle away.<br /><br />As for your Q, like said above it depends. I've seen kids skiing behind a 15 hp on inflatables. When I was a teen, a friend of mine had a zodiac with a 35 hp on it. We skiied slalom behind it, and could ski double (2 people) if we got up on 2 skis. I have no idea what that zodiac was rated for, but my guess is that it was overpowered. FYI, it was a bit of a wild ride in that boat when someone was slaloming hard behind it. With such a light boat and relatively low torque engine it really slowed the boat when someone pulled hard. The 35 hp was marginal for deep water slalom starts.<br /><br />Also, don't forget the weight of the spotter in the boat... in my experience, the performance of inflatables is very affected by weight.
carljh
Should have explained a little better, I was asking what HP I would need so that I can get an inflatable of the right HP rating. <br />From the replies I guess that I should be looking at a minimum of 10HP.
TOHATSU GURU
If I understand how you are approaching this:<br /><br />You need at least a 10 hp on a 10'. A 9' will ride low in the water and have a hard time getting on plane while pulling a tube.
deejaycee_2000
I would say a 30hp - 50hp on a nice 4meter rigid inflatable can pull anything .... it's cheap, fun and durable ...
