I have an old trolling motor, and I am trying to find out what sort of thrust it has.<br /><br />According to the plate on it, it is an Electra Pal , made by Jet Co Inc.<br />The only other labels on it are one on the control box that says Solid State, and one on the prop unit that says Permanent Magnet Power.<br />The Prop is about 5 inches across, two 2 1/2 inch blades<br /><br />The control box has a red switch for forward and reverse, a switch that changes it from full to variable power and turns it off, and a knob for changeing the speed.<br /><br />Any info on thrust or anything else you know about it would be great<br />Thanks<br />ben
