where can I find more info on doing this conversion? doing some web searching also, found a few pics. looks like a need some sort of coupler, 25mm to about 1/2 inch. and I figure an adapter plate out of 1/4" aluminum ideally, steel if I have to. opinions, thoughts, ideas welcome
update, on my eska project. I got the carb running fine, motor starts on 3 pulls, put the motor on the boat in the water, and it wants to start. take the motor off the boat, back on the saw horse, and it will start. the problem is it doesn't have enuf compression to run in water. I never tested the compression with a gauge. I just turned it over with my thumb over the hole, and it seemed adequate at the time, blew my thumb off the hole. today I did that and not much pressure. oh well, live and learn.
so I figure I can mount a new lawn mower engine way cheaper than buying an outboard. in this week's paper a guy was selling 2 small hp Mercury outboards, one a '68 and the other a '69, $400 each for 42 yo motors. and another was $950 for '95 Johnson 9.9. I just say ouch, I'm cheap I know but a grand for a 15 yr old motor??? not me.
