info on SX outdrive
jfgln
Hello, I'm looking at a boat, a 1985 Starfire 245, that is powered by a volvo penta 5.7 with an SX outdrive. Are parts readily available for this model outdrive? Any other pointers on what to look at would be appreciated.
Thanks,
Jeff
Sparkinator
Re: info on SX outdrive
Sounds like a replacement motor/drive. I don't think the SX came out until the joint venture in about 93 or 94. Parts are readily available and they are supposed to be really good drives.
jfgln
Here is a picture. Is this an SX?
Lou C
Nope looks like an older style Volvo....they are supposed to be very good drives but make sure that your local service centers work on them because they are completely different than the SX drives...and make sure you can still get parts...if good service is not available I'd pass on the boat....Call around to I/O shops and ask about this...
Beyond the drive...a boat that age can have a LOT of wood rot...be very careful about checking the decks (floor) engine mounts and tramsom....that blue gelcoat looks pretty oxidized and that alone is a lot of work to get looking good....no such thing as a cheap old boat...they all extract their cash out of your wallet sooner or later...
jfgln
Thanks for the feedback. I will have to take another look at the outdrive, its advertised as an SX, but the dealer must have got it wrong.
bruceb58
That is either a270 or 280 drive. They are excellent drives.
I would be more worried about the age and condition of the boat/engine than the drive.
Don S
It's at least a 290 outdrive, it has (from what I can tell in that picture) trim cylinders. The drive is great, there are no problems getting parts for them. They are super drives, have owned them myself. It can also be converted to a DuoProp by replacing the lower unit of the drive. Talk about the difference between night and day in that boat .............. :D
jfgln
Thanks again for the great feedback. This boat fits my needs, a hardtop that is affordable. I just wanted to confirm that parts were easy to come by. I like the DuoProp idea.
HT32BSX115
That boat would REALLY get a performance benefit from a duoprop.....
If it's in otherwise good condition you might be able to get a good deal if you "lowball" them....
Boats don't usually sell well this time of year.....
Good luck,
Rick
jfgln
I took another look today, the drive has an SP sticker on the side. I decided to pass on this boat and keep looking. Its been sitting for two years and shows it.
Thanks,
Jeff
Don S
So what, that stands for Single Prop. Doesn't say anything about SX
Just don't let that the difference between the letters P and X be the deciding factor in your decision
jfgln
I think you misunderstood me. I like the style of the boat. I have no problem with the outdrive. The boat hasn't been ran for 2+ years. It needs a fair amount of work to get it back on the water. I don't mind doing the work if the price is right. They just want too much $.
I was curious what the SP stood for, it seems obvious now.
Thanks,
Jeff
Don S
That's a good reason to walk away, I just didn't want you to walk away from a boat you liked because of a decal and misunderstanding.
