Re: Info required on Tern 6hp aka Terhi 6hp Valmet Finnish air cooled outboard
I have just picked up one of these engines, Few things i need to know,
Whats the spark plug gap?
And what fuel mixture? 50:1? 20:1? I tried 20:1 but it was very oily and not firing i dunno if its because i havent replaced the plug (its been sat for 30 years in a garage its pristine inside!)
Also did anyone have a manual for it?
thanks
Alex
Hi!!! I'm delighted that somone else has found one of these great air cooled outboards!!!! I think it's a credit to iboats that it puts admirers of these engines in touch!!!! Great website!! To answer your questions:
1. Spark plug gap - I scoured the net for hours for info on this and found nothing! I was working from no info at all with a defective plug. I cleaned around the contacts and coil beneath the flywheel without resetting anything and I set it for approx 30 thousandsth of an inch and held it against the engine casing and it sparked well. I left it at that.
2. Fuel mixture - this was a problem for me as I knew the engine was prob from the late 60's and I suspected that at that time that german two stroke engines (mahle head, mahle piston, bing carburettor=german) probably didn't run on 100:1, so I've ran her on 45:1 - On a 45:1 mix she starts just fine however she isn't running as smoothly as I'd like-she ticks over/idles ok and at full revs is great but in between those she is temperamental!! I'm a bit nervous about weakening the mix still further to smooth her out over the entire rev range as I don't want her to seize-altho I've stripped the head and piston and if she did seize it wouldn't be a problem putting her back together again (when I was restoring her I bought a 51mm piston ring for a husqvarna chainsaw and that fitted perfectly!!)
Please note that I've stripped this engine/carb/leg/modified a yamaha prop for her and cleaned or replaced every nut and bolt in her. Of all the air cooled engines I've worked on, I think this is the most simple and reliable I've ever seen-and I've seen alot!!
Owners manual - I can't find an owners manual at all. Apparently there's an old guy in Finland that was a worker in the factory-however apparently he doesnt speak any english so thats no help I'm afraid about a manual. I found a link to a website in danish that may have info on them but I don't speak any of the scandanavian languages so I'm at a loss. On a happy note tho - I obtained a husqvarna piston ring and the bing carb seems common enough so interchangeable parts should be ok with some care.
Please note that it's a credit to the quality of the engine and the manufacturers that a box of rusted parts can be taken, (particularly a really badly rusted small end), cleaned, re tapped a stud into a tapered crank and fitted all together and a 50 year old engine starts and ticks over happily!!
I hope you get yours up and running soon!!
Thanks,
EugeneB
