INFO WANTED EVINRUDE TILT/TRIM
L ARRY
HI<br />I HAVE A 1976 EVINRUDE 85 HP.<br /> IT HAS THE EXTERNAL PRESTOLITE,<br /> PUMP.<br /> THE PROBLEM I THINK IS IN THE VALVE BODY OR<br /> THE MANUAL RELEASE VALVE.<br /> WHEN MOTOR IS RAISED I CAN HERE THE FLUID <br /> BY PASSING IN THE VALVE BODY AND MOTOR LEAKS<br /> DOWN. I CAN TAP ON IT AND IT LEAKS DOWN FASTER.<br /> IF ANY ONE HAS OR KNOWS WHERE I CAN GET A<br /> SCHEMATIC OR PARTS BREAK DOWN WOLULD A GREAT<br /> HELP ALSO A LINE ON PARTS WOULD BE NICE !<br /><br /> THANKS LD
ezeke
Re: INFO WANTED EVINRUDE TILT/TRIM
LD<br />I have the factory manual on the 76, so maybe I can help.
