Information
diegome
I just got this force 125 hp but I don't know the year and what kind of engine this is? on the plate the model # 1251X8C and the serial # 2692
Please I need as much info on this engine as possible.
This engine is going to replace my1991 120hp(force) that I blow last week.
Thanks to all:%
eross
power tilt trim 1988 force 125 o/b
i need a o-ring kit for the hydrulic unit not the pump or motor any one know where i might be able to find one please help
roscoe
Re: Information
125 hp
25" extra long shaft length
Made for a Bayliner (decals)
1988 model year
Production run "c"
2 cycle engine
50:1 fuel/oil ratio
Keep the old engine, many of the parts are interchangeable.
diegome
Re: Information
Thanks for the info
I also need to know if I can use the lower unit from the 1991 120hp. the lower on the 125 has a broken piece.
I noticed that the water inlet in the 125 is different and i'm wondering if the internals are different other wise they look the same.
Thanks again
roscoe
Re: Information
Sorry, not sure.
One may have dual exhaust, and one may have a 2 piece driveshaft.
Probably have to pull them off and try it.
eross, no kit available.
one guy was putting a kit together and selling it on ebay, don't know if he still is or not.
You will likely have to try to find them at a hardware store or hydraulic repair shop.
Try a forklift repair shop.
diegome
Re: Information
Thank You Roscoe for all you info.
I will be swaping engines this weekend is there any advize?
Thanks again..d:)
