Infrared Temperature Gun Recommendations
bkwapisz
I want to get a Temp gun, and was wondering if anyone had a recommendation or a warning as to what to get or what to stay away from. Seems they range in price from $20 to about $50. Money in this range is not the issue, but I'd rather get a decent one that will be around for a while than to get a crap one that will quit after 3 uses.
I'll be taking temps on outboards, RC car engines, etc.
Thanks!
Brian.
Bob_VT
Re: Infrared Temperature Gun Recommendations
Interesting timing on this.... I just today borrowed one to see how hot my new oven element is. A friend lent me a handheld MATCO too one that seemed to work fine.
I was tempted to buy a cheapy off ebay but borrowed a decent one instead. I actually asked my friend and he got his from the Matco tool guy. My suggestion is get a decent one from a reputable source...... check some of the local tool vendors. I had even seen a few in the northern tool catalog that looked good.
Yup my new oven element was running 75 degrees hotter and with the adjustments I was able to narrow that to about 50.... at least the wife will know what the oven is doing now.
bkwapisz
Does anyone know if Raytek is the same as Fluke? I know that Fluke owns Raytek but they both advertise similar-looking meters and Raytek is about 1/2 as expensive as a branded Fluke.
CatTwentyTwo
I have the Fluke 62 Mini and have been very happy with it. I use it mostly for quick checks of my trailer wheel hubs and brakes and trust it to be very accurate. I'm not sure how the Raytek brand compares.
JustJason
I have a Raytek. I believe they were their own seperate company and fluke bought them out some years ago. But with anything Fluke related, even fluke owned but under a different name, you can bet your getting a quality and highly accurate tool.
rbh
If its a $1.99 on special opt for at least the $20 one.:D
salty87
i went the harbor freight route and have been happy.
they are also good for checking a/c or heating output temps, finding spots where insulation isn't good or there is just air leaking past door jams or windows.
marlboro180
I have had a Raytek Mini-temp for quite a few years (10???) Use it for r/c motors , pipe/ boiler / a/c work, tire inflation , hub checks, etc. It has been beat on, dropped down into a flooded elevator pit, covered in paint and iso :eek:and generally abused for years yet refuses to give up the ghost.:)
The only thing it does not like is sitting in a cold truck and then going into a warm environment, doing so will give false reads until it comes up to something close to ambient temperature. Same for warm gun going into cold outside...or into a walk in freezer. Very good purchase overall.
bkwapisz
Raytek is looking good. I've seen some on ebay for $44 or so, smaller ones for less. Might go that way after hearing the comments here.
HANGEYE
I also have a Raytek mini temp. It's about 10 years old and works perfect. I even use it to check the temp of my oil when I cook fish. It matches (within one degree) my digital thermometer. Can"t say enough good about it.
Bucks45
I have the Raytek mini. It works great.
