Re: ingition
Well its certainly a 1975 ..if it has two HT cables comming out from under the flywheel its Magneto ( and two thin stop cables) If you have two coils mounted on the side its battery ignition with a coil ...Not 100% but think 75 is too early for CDI. Dont leave the igniton on as the coils get very hot and split ( epoxy ) and biggest problem is the flywheel comming loose,,breaking the key and then the timing ring rotates ...85 ft lb on the nut...I have locked my timing ring into place and have a seperate key for the flywheel ..so if it moves all keeps going .....let us know if you need more advice
