initial rolling torque settings
ptj11
I have a 2000 volvo penta 5.7Gs with DP-SM 1.95 out drive. I am reassembling the lower unit of my out drive. I did not replace anything but seals and o-rings. All gears and bearings are good. I am installing the vertical driveshaft. I have seated the driveshaft bearing cup. The workshop manual page 5-21 says that I have to tighten the driveshaft retainer by hand and set the initial rolling torque at 2-4 inch pounds. Then I go on to install the bearing housing and retainer. If i leave the drive shaft retainer at 2-4 inch pounds I am afraid that it will loosen up on its own since it is only hand tight at 2-4 inch pounds. What am I doing wrong?
Grub54891
Not positive on Volvos, but I think you have to use a new nut every time. It say's initial rolling torque? To me that indicates there should be a second step in the process.
muc
"Retired" Association of Marine Technicians...
Your fine. The Volvo tool for that job is meant to be used by hand. Tool is knurled and has no provisions to use a wrench or breaker bar. Hand tight is enough to get the 2-4 in lbs. any time I have needed more torque to get 2-4 in lbs it was because of a bad bearing. The o-ring that goes around the retainer will hold it from loosening when you put the upper case on the lower case and tighten the bolts.
