Got an old mid 70's Cobalt with a GM OMC 225 V8 that had been sitting in storage for 5 years, not properly stored. Good news it is running now, quite well too.<br /><br />After having multiple problems with timing I decided to do a static timing. After turning over engine to have the timing mark on flywheel roughly where it is supposed to be I popped the distributor off to see I had it 90 degrees off! Ouch. I then, with the motor off and ignition on, put the cap back on and used a voltage meter connected to 12 volt lead and turning the distributor to see exactly when the points opened and tightened the ditributor down. Turn key and Varrooom! Perfect.<br /><br />Problem now. Lots of nasty chocolate shake oil. I am not going to panic yet, it is an old engine and things have been sitting for 5 years. I am pumping out the old oil and was going to run some used motor oil through it a few times to flush it out and check for more water before adding good stuff. I was told that adding some transmission fluid as well would help in this process of flushing it out. Does anyone have any tips/ hints at what to look for in this process? What pump to use? I am using my neighbors old medical cystalic pump, which works but is very slow.<br /><br />Any help would be much appreciated.
