Injection Oil Res. 2100DC Sea Swirl (2000)
Wurm Slinger
First off, Hello everyone, brand new to the site. I bought a 2000 (year) 2100DC Sea Swirl Striper late last season and have yet to find a dip stick or gauge telling me how much injection oil is in the reservoir located below the floor near the battery compartment. I have a 150h Evinrude Outboard. Any help or directions would be greatly appreciated.
WIMUSKY
Wurm, welcome to the forum. You only need 1 thread per issue. I deleted your other duplicate threads.....
Have a good good nite......... :)
dingbat
Never seen one with a dip stick. Mine has a sending unit and a gauge on my 3 gallon tank but I still open the hatch and look at the tank (opaque) from time to time to be sure.
seahorse5
The oil tank has a LOW OIL alarm plus you can visually see through the tank or remove the cap to know the oil level. There is an optional oil level gauge that works like a fuel gauge.
Chris1956
Your motor will run between 50 and 60 ::1. So if you put 25 Gal of gasoline into the fuel tank, expect to add 2 qts (more or less) of oil to the reservoir. The low alarm will sound when you are down to less than 1 gal of oil in the tank. At least that is what I think I remember. I fill my reservoir after each fishing trip. That way I can gauge the amount of fuel used.
