have a 1985 115 inline 6. It was a little underpowered lately, felt like it was only running on 5 (been there before). Put new plugs in, since they were a year old, thinking that would do the trick. It still acted the same. When I pulled the plugs I noticed #6 was clean with what looked like liquid spotting. Checked compression, all were same as last year except #6 which was about 7 psi lower (now at 130 psi). Talked to a guy at a local boat shop and he said it looked like the plug was washed with water. He said the inlines had a history of water jacket gasket leaks and causing such problems. My question is, does this sound right? If so, would replacing the gasket (assuming that is the problem) be enough or would I need to do something else because there was some water in the combustion area?
