Inop trim
Big Dannyboy
When I tried to startup my 1988 100 hp Mercury outboard this year the electric trim would move the engine up but not down. After a few trys it ended up in the full up position. When I activate the down switch I hear a click but it does not move....Anybody have an idea where to start in trouble shooting the problem?
Chris1956
Re: Inop trim
The parts list for that motor shows two different PTT systems. The three ram system has two solenoids, while the single ram system has two relays. Troubleshooting is a bit different for each. which one do you have?
Fl_Richard
Re: Inop trim
If you have the two relays just swap them. If then you have down but no up you'll be needing a new relay :)
Big Dannyboy
Re: Inop trim
I have up but not down and am not sure whether it is a two relay system ir not. How do I tell?
