Inop water temp gauge
Nittoman
Water temp gauge inop.no sensor on tstat housing but has 1 wire switch on front of intake manifold.not sure how these gauges work??thanks.
alldodge
All switches Temp and oil pressure will be connected with a single Tan/Black wire
Temp sender is connected with a single Tan wire
Check for 12V and a ground at the gauge. If power and ground is there, then take the Tan wire and ground it. Grounding should cause the meter to peg Hot
Always good idea to let folks know what your working on, otherwise it might be a chain saw. I'm assuming its a 4.3 GL because of the tags, but could use more info
Nittoman
Ya 4.3 gl.1999. Installed new sender checked wire from sender to gauge all good but not heating up.installed new impeller and t-stat and gauge not working?ideas?
alldodge
Is the gauge not showing the motor is heating up or the motor is not heating up?
dypcdiver
The body of the sender needs to be grounded, some times people add too much PTFE tape or the like and it is isolated ie. not grounded/earthed worth checking.
