rbiankowski
- Oct 15, 2016
- 42
I've driven an hour and a half to look at this boat last week and everything looked great visually: https://www.facebook.com/marketplace/item/1601434969971030/
I had a certified marine technician / surveyor do a full inspection and run it this morning. Below is the list of issues he found. He claimed most of these are lack of maintenance issues but it is above average on what should be wrong at this age. Please help me assess costs per item if you have any experience with these issues:
| Distributer cap needs to be replaced |
| Engine Temp. Gauge Reading Hot. Gauge to be replaced |
| Trailer Brakes Disconnected. Wires need to be fixed. |
| Boat missing 3 snaps for cover. Install missing snaps. |
| Passenger side windshield loose. Secure windshield. |
| Horn doesn't work. Fix horn. |
| Rear courtesy light doesn't work. Fix wiring. |
| Lower unit gear lube milky - needs drain pressure testing |
| Bellows to be replaced |
| Engine not pumping water? Water impeller to be replaced |
