Inspection tips appreciated!!!
lukeb83
hey guys, i have a 1986 larson citation bowrider with a 140 hp 3 liter mercruiser and an alpha 1 outdrive. i had a serious over heating issue and wound up having to replace the exhaust bellows, water cooling hose, impeller and water pocket. i found out last nite i will also be needing exhaust shutters. i am just curious if there is anything else i should be inspecting that may have been affected by the overheating. Im going to take her out this weekend and it would really suck if i missed something. thanks for the input. i couldnt have done any of those jobs without this site!!! :)
dubs283
Re: Inspection tips appreciated!!!
check any and all wiring in the engine compartment that is near the engine, i have seen whole wire harnesses melted from overheating
if you really cooked it you may have runnability issues (head gasket, cracked head, etc...) - a quick compression test on a warm engine will give clues to condition
lukeb83
ok. thanks. so just let her warm up and check compression on the cylinders? any idea what they should he hitting at?
dubs283
with the throttle plates open you should see no more than 15% difference across all cylinders
lukeb83
i have also heard that exhaust passages being clogged with rust can be a factor in overheating and my cause problems. where should i check for this problem?
