Hi all<br /><br />I recently replaced my o-ring and prop seals on the bearing carrier for my lower unit and now want to reassemble. It popped out easily enough when using a flywheel puller but have some questions about how to put it back together. I have installed two long bolts to guide the bearing carrier back into the lower unit but it seems that I can't get it all the way back in place where I can remove the long bolts and use the 4 short bolts with o-rings to fix it in place. Should it slide easily inplace or is some force required to get it back into position? Don't want to start pounding on it if I have something not lined up correctly.<br /><br />All help is greatly appreciated
