Re: Installing 115hp Merc - any tips?
Bexi, Check the mounting holes. Somewhere along the line Merc standardized them. The '77 has the old style 3/8" bolt holes (six bolts if you have PTT), plus a transom clamp. The newer style is 4 1/2" bolts, and no transom clamp. If the boat wiring harness fits, it should work OK. The controls will work OK as well. PTT will likely be different. Steering and control cables will be compatable
