MickLovin
Master Chief Petty Officer
- Feb 18, 2013
- 822
HI again, sorry to ask so many questions, but is it worth putting a temp. gauge on my Chrysler outboard, I know the buzzer definately works but not sure if the sender works or how to test it, does it have an Ohm reading? Every time I have tried to either put a tell tale in or a sender into the hole above the thermostat housing where the s/s flat head grub screw is, I have been unable to take out the grub screw. I have used heat and a centre punch tap so as not to stuff the flat blade screw head. I have had 4 Chrysler motors all with the same problem of trying to get the grub screw out but with no luck. :indecisiveness::noidea:
Ok question, is there an easy solution to this, remembering I have used heat, Penetrol and a impact screwdriver all to no avail, has anyone tried using the freezing solution and does it work??? To be honest I would prefer to have both Gauge and buzzer. So any help here is much appreciated. Also I believe the buzzer goes off at 160 degF? would you get a gauge from my thermostat opening which is a 110deg F, so 40 deg F to 160DegF ??
