I have done it in the water, about 8 ft deep, salt water. Using a 8ft aluminum boat to access the motor being worked on. If that wasn't hard enough, broke off several of the bolts holding the lower unit on. That was the LAST time I tried that stunt. Hey, have you tried turning a wrench while sitting in an 8ft aluminum boat? Instead of the wrench moving, the 8ft boats skoots away. Then imagine getting the heavy lower unit back up in place without skooting away. Needless to say, I did have enough forsight to tie a rope to the unit to retrieve it if dropped.
