climb29028
- Jul 17, 2013
- 41
Hi everyone. I have a question regarding mounting an outboard motor. Would it be a good idea to coat the inside of the holes that have been drilled into the transom to mount the motor with Marine Tex before the bolts go through the holes? It just worries me that the Sikafex (or whatever sealer they use) is not enough to keep all water out from seeping into your transom. At least if you have Marine Tex sealing the wood inside the holes it will prevent rot from happening if water get's through the Sikaflex? What are your thoughts on this? Thanks.
