This is embarrassing, but it's been a long time since I worked on or installed electric brakes. There are two wires present in each brake assembly. Do I connect them as: one with power, the other ground? Or do I connect them both to power and assume the ground is provided through the brake assembly (metal bolted to the trailer).
I've got the assemblies mounted, with the new drums and wheels. I have the breakaway switch and battery mounted and know how those are wired. But when I crawled under the trailer and found two wires to connect, I honestly couldn't remember how they were used.
Thanks in advance for any advice on this.
