Hello to all,
I am the guy who had a lower unit leaking OIL from the weep hole in an earlier posting. After some investigation and a vacume test, I found that indeed the seals around the drive shaft (under the water pump) were bad. I went ahead and re-sealed the entire lower unit, and I can proudly say that it is holding 13 lbs with no leakdown.
Now, I have run into another issue and I am looking for some "Tricks Of The Trade" from you Johnson/Evinrude guys. Like I explained earlier, I have a lot of experience with Mercury, and older OMC V-4's. This 2003 Johnson 90 (Bombardier) is driving me crazy. I can't seem to mesh the lower unit to the mid-section and get everything to align properly.
Any hints or tricks someone can pass on to me?
