Installing Motor - Force 70
atengnr
Hey all. Whats the easiest way to lift this motor with a cherry picker? Where are good lift points?
Thanks alot.
atengnr
Thanks. Happen to know the bolt size of the flywheel puller bolt holes?
Tassie 1
You tube
do a search for outboard motor lift
two local chaps show how to do it,
have used that method several times since
cheers
kbh121956
3/4 national fine thread. Get yourself a nut and weld an eye on top of it. I've made several for friends. It will cost about 8 to 10 dollars in materials. The ones that I've seen on eBay go for 40-60 dollars
