Hello All,
I am mounting my 2001 50 hp Merc on a new boat and decided to install a Tach so I can prop it correctly. I have the harness that plugs into the controls and the wiring color code chart I know the grey is the Tach wire the black is the ground but on the chart is says the purple is the instrument feeds. I would like to know if by this they mean that this is a hot wire when the key is on. The gauge says ignition so I am assuming this is the wire for that terminal. There are a couple other wires in that harness but I believe these are not needed for the tach. Any info would be appreciated.
Thanks
Thanks
